It is currently Tue Jul 22, 2025 6:04 am
PostPosted: Sun Mar 11, 2007 4:20 am
Ran across a deal on a floor model Delta 1.5 HP single stage dust collector. Just wondered what you seasoned woodshop pros advise? Will this handle a beginner shop with the avarage tools? (thickness sander, jointer)
PostPosted: Sun Mar 11, 2007 4:43 am
Joe,
That will just suffice for what you mentioned, as long as the runs are short and direct. You'll probably lose effectiveness if it's hooked up with overhead runs, multiple connections and blast gates.
PostPosted: Sun Mar 11, 2007 4:49 am
Also, it would pay you back in health to invest in a 1-micron or less cartridge conversion, such as this one.
If you haven't already, spend some time looking at Bill Penz's site. Better yet, spend a lot of time there!
PostPosted: Sun Mar 11, 2007 5:10 am
State: BC
[QUOTE=burbank] Joe,
That will just suffice for what you mentioned, as long as the runs are short and direct. You'll probably lose effectiveness if it's hooked up with overhead runs, multiple connections and blast gates.[/QUOTE]
I agree. Small dust collectors can do the trick if you keep them close. It should not be an issue rolling them around the shop.
CVT Inc.
PostPosted: Sun Mar 11, 2007 5:26 am
First name: Scott
Last Name: Thompson
Joe, I have a 1 HP Delta in my small shop and it works very well. I run it on my bandsaw, drill press, thickness sander, router table and sanding station. I have two connections with flex hose and gates that I move where I want them.
I also have a Delta air cleaner mounted to the ceiling for smaller airborne particles. The two together work very well.
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Sun Mar 11, 2007 5:38 am
I have such a dust collector. As advised I just roll it from tool to tool and use a relatively short flexible pipe. It works fine for keeping the chips away so that your tools (i.e. planer sander etc) will work properly.
I am a little wary of thinking that any hobbyist type collector will really keep the air clean, especially when using a table saw or router. So, I also use an overhead dust filter and generally wear a mask when in the shop. I'm fortunate to be able to have a small area in the house that I use for clean detail work that doesn't create dust.
David White, Toronto
PostPosted: Sun Mar 11, 2007 12:59 pm
Last Name: Lloyd
I’m happy with the 1 HP Delta, which I roll to each work site. I also have an air filter which works in unison with the Delta and I usually wear mask.
Michael Lloyd
PostPosted: Sun Mar 11, 2007 4:31 pm
Thanks for the replies. It is on wheels so moving it around or placing it closest to the biggest dust makers would be logical.
Users browsing this forum: Bing [Bot] and 21 guests
